跳转到主内容
A mini tablet computer designed by Blackberry and manufactured by Quanta Computer in 2011. Model number RDJ21WW.
35 个问题 查看全部
What should I do if I dropped my tablet in the water?
I was using my tablet near the sink and it slipped out of my hand, landing right in a bowl of water. I need to use my tablet asap! What should I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
ok so i was spaying perfume all around my room and it got on my tablet so I got a big bole of rice and i sat my tablet in there the next day i try it and i wont work it always says there is moisture detected in your tablet what should I do!!!!
完成的
添加一条评论
6个答案
最有帮助的答案
Keyon Keshtgar, as part of your assignment :-) it is important to learn the importance of good information. SKIP THE RICE. I know it was on your mind;-). Rice has no value in repairs and is the equivalent of doing nothing. First thing you want to do is to stop using your device. Open it up and disassemble, this video should help. Then clean all parts with high grade 90%+ isopropyl alcohol. Make sure that you do clean all connectors and cables as well. Then replace the battery and reassemble. Two more things. First, hast makes waste. You do have to take your time and get it done right. I know you said you needed it fast, but you can not rush a job like this. Second, water damage is the hardest to troubleshoot and to repair. Even so you may do everything right, there is still a big chance it will not work. This is dependent on where and what part shorted out (if any). Hope this helps, good luck.
这个答案有帮助吗?
得分 3
添加一条评论
First, turn off the device immediately. There's a chance nothing is wrong yet, but if water seeps in while the tablet is still running, it might short and fry a circuit. So, turn off the power and make sure there's no electricity flowing in those circuits.
If you need to use your tablet "asap," you might be out of luck. The safest way to ensure your Playbook keeps working might take some time.
I recommend you find some uncooked rice or silica packets (the little packets labeled "Do not eat" that you get in things like new backpacks) and encase your tablet in that. This will serve to absorb the water. Leave it like this for some time, preferably an afternoon or a couple hours at least.
After a while, take the device out of the rice/silica and disassemble it. You're going to go hunting for leftover water and anything left behind when the water evaporated. Check the circuit boards, battery, and electronics for traces of water and clean them off with a cotton swab or microfilter cloth and isopropyl alcohol.
Once you've thoroughly checked the device and ensured it is dry and clean, try turning it on. If things don't work from there, try the Troubleshooting Guide. At that point, though, it's pretty likely you've fried the battery or, worse, a circuit.
这个答案有帮助吗?
得分 1
添加一条评论
Isopropyl 99% in an ultra sonic cleaner (jewellery cleaner machine) - take the motherboard out and set it to clean at 80 degrees and then look for corrosion any clean that off with a toothbrush a soft one - please correct me if I'm wrong ifixit because I'm new still for now but ya and leave it in for a while not too sure how long I'm sorry - you will see a bunch of guck and stuff floating from the millions of bubble that get into every single little hole we can't and you should be good to go! Do some research on it and look up what I typed here and you'll be in the right direction ! Hope I helped
--Motivator Luke W on fb if you want to chat but these ifixit guys rock this stuff like you wouldn't believe ! I love you guys and gals if any!
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
Put it in rice for about 24 hours or until you think it's ready
这个答案有帮助吗?
得分 0
添加一条评论
Well what if it's like one second
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keyon Keshtgar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 6,226
