跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
568 个问题 查看全部
Will the late-2013 adhesive strips work?
Is the iMac Intel 27" (EMC 2546 and EMC 2639) Adhesive Strips Kit compatible with this model as well?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I see no reason for them not to be.
这个答案有帮助吗?
得分 1
3条评论:
From the kit picture the strips seem to be cut to a specific pattern. I thought perhaps the new display may have changed the internal layout a bit from the EMC 2639. I'd guess that even if there were some differences the strips could still be modified and used, but I've never owned nor serviced an iMac before, so to be more specific...
Was the unit from the teardown reassembled? Were the adhesive strips from the EMC 2546/EMC 2639 kit used? Did they require any modification?
If they work as-is the iFixIt team could update the compatibility list on the kit's product page.
完成的
any Updates here?
完成的
IFIXIT lists the tapes as compatible: "iMac Intel 27" (EMC 2546, 2639, 2806) Adhesive Strips" click on the above link.
完成的
添加一条评论
添加你的答案
Ian Brandt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 158
