跳转到主内容
Repair guides and support for the ultra-light laptop computer line by Toshiba.
35 个问题 查看全部
Best method to remove keyboard for Toshiba Z835?
Need to replace Toshiba Protégé Z835-P330 keyboard. Model #PT224U-001001. Suggest best method of removal. Nothing on line other than it may be glue down. If so, where are the glue lines and can the key buttons take the heat from air heat gun?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi,
This is a guide for Z830/Z835 (Z830 is European variant):
http://www.manualslib.com/manual/581306/...
Keyboard removal is at page 333. But you must disassemble the laptop and disconnect the KB flex cables.
Regards.
这个答案有帮助吗?
得分 1
添加一条评论
My space bar quit working. Bought keyboard from Amazon-about $30. Am done and it works so declaring victory. Unfortunately, I took no pictures. The keyboard is stuck/glued on. It seems crude and brutal but slide a screwdriver or similar under the edge of the keyboard and pry it off. You will destroy it. There are 2 connecting ribbons, one wide, one narrow. Difficult to see where they go, but--take the back off. You will need a special tool to remove the center screw-a Torx 7 security(has a hole in the center-kit cost $6 from Amazon). Loosen the battery(the largest black thing) and move it towards the edge. The two ribbons come up at about the middle of the center edge of the battery. Wiggle the keyboard to see which ones they are. Unclip them and remove the old keyboard. Slide the new keyboard ribbons in and connect them-it is fiddly. Pull as much of the ribbon as you into the back of the laptop do the keyboard lies flat. Replace the back. You will need to secure the keyboard to the laptop. I used glue around the edges and used the foam packaging sheet that came with keyboard to keep the keyboard in place while the glue dried, and closed the laptop with the foam inside. Hope this helps. Took me 3 hours--could do the second one in 20 mins.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
wchoy2526 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,054
