跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
683 个问题 查看全部
Can I add 1x 4G or do I need two x 2G
I would like to upgrade my MacBook (mid 2010 white). But not sure if it has two or 1 slot memory....
Do I need 2 x 2G or can I use a 4G?
Thanks
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
1个答案
已选择的解决方案
First you should make sure your firmware is upto date. Follow this Apple TN: EFI and SMC firmware updates for Intel-based Macs
As to upgrading the RAM follow this IFIXIT guide: RAM Replacement.
And lastly, Here's the information you'll need on the memory from Apple: MacBook: How to remove or install memory. Basically: PC3-8500 DDR3 SDRAM 204pin SODIMM Memory
As it to the max amount of RAM this system will support with the updated firmware you can install upto 16GB of RAM using two 8GB modules depending on your OS (see below note from EveryMac).
*Apple officially supports a maximum of 4 GB of RAM, but third-parties have determined that it actually supports 8 GB of RAM running Mac OS X 10.6 "Snow Leopard" and 16 GB of RAM running OS X 10.7.5 "Lion" or higher and the latest EFI update.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
florence 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 83
