I need the hose configuration for inside the unit.
I need a schematic of the interior hose configuration, i took it apart to clean & forgot how to put back can you help please?
can you show me the hose configuration for inside the unit I took it a part to clean it and can't figure out how the hose go
这个答案有帮助吗?
Here's a picture of the interior of a Bissel ProHeat, I hope this helps
这个答案有帮助吗?
No es la misma el modelo mío es 9200
I took off the hoses from the front not the back can you send me a picture of the front
I think I have a solution for you in the form of a Service Center Guide.
I'm in the same predicament! I took off hoses since all were clogged and now I cannot figure out how to put the hoses back together. Is there a schematic somewhere? Its a Bissell ProHeat and the tubing coming from the hose attachment within the case is what I cannot figure out how to reattach and where?
Please describe(or send a photo of) the area you require guidance and I'll create a tear-down guide for you.
Kind regards Panshaker Ross
这个答案有帮助吗?
Forgot how to put the hoses together to my Bissell ProHeat complete Pet 2x meet the front of the vacuum cleaner not the back
This may help you. There are schematics for hose configurations for several models which are very similar. They do not show the hose configurations for the clean shot nozzle but it is easy to decipher on your own Brain Power.
这个答案有帮助吗?
If you have a Service Center Guide for the Bissell 9500 ProHeat 2X Clean-Shot I would very much like a copy of it myself. I also have this machine and have it working again except after everything is closed back up. Somewhere inside something is binding (suspected) but I can not locate what it is. Any thoughs will also be well taken. Short of a laser leveling device casting a light on the area to get everything below a specific level I am out of ideas. These machines are JUNK was the conclusion I came up with after going inside.
Thanks Monty this is the same manual that I found once I sat down and actually started doing my homework, I have the machine back together and working something that the sweeper repair place couldn't do
i need hose configuaration for a bissell pro-heat carpet clean
这个答案有帮助吗?
Me too. I cleaned the interior hoses that were clogged and now I have one hose that I don’t know where it connects to!
Because i took it apart and it took awhile to get the part i need and im a little lost about it
这个答案有帮助吗?
My bissel has the indicator that spins on top of the switch s
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 59
总计 6,210
3条评论
Kind regards
Panshaker Ross
由 Ross Mckay 完成的
I need a hose schematic of a bissell 9200 pro heat
由 gary4851 完成的
@gary4851 You will find what you need here --> https://evacuumstore.com/images/proheat-...
由 Monty Howard 完成的
