lg g2 won't turn on, only vibrates
lg g2 won't turn on, only vibrates when i am pressing the power button
Please help
When I had this problem, it was the battery. It was completely dead and required an official charger to charge the phone. Worked fine once it was charging with an official charger.
这个答案有帮助吗?
I had the same problem, but thank god I'm an Verizon employee. I let it charge all the way and then it worked fine!
这个答案有帮助吗?
Still vibrate, so there is the power. If the charging LED light come on when plug charger? It's more likely there is something wrong with the LCD screen.
这个答案有帮助吗?
I dont know, honestly. Ive been having the same problem. None of the above solutions help. It vibrates when charged and when the power is held down. No LEDs turn on, and the screen is just black. The only sign of life from this thing is vibration.
这个答案有帮助吗?
过去的24小时: 0
过去的7天: 5
过去的30天: 27
总计 11,142
I have the same issue! I replaced the screen and its doing nothing but does vibrate sometimes. So I'm sending the screen back and thinking it may be possible bad replacement part.
由 rockndave02 完成的
