跳转到主内容
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 个问题 查看全部
问题已关闭
Is it worth it to try and fix this?
Hi All,
I've got an iPad 4 that my friend gave me to fix, seeing as I've fixed a couple of iPhones in the past. (He got it from a friend, who tried to fix the screen himself, tore it apart, and gave up). I'm wondering if anyone could shed some light onto what parts I'm missing, what parts should be replaced, or anything along those lines, based on pictures.
I appreciate any and all help I get!
Pics at this link:
http://s44.photobucket.com/user/pzedzik/...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I've only ever fixed a few iPhone 5's --> I realize that iPad is very different.
完成的
添加一条评论
1个答案
最有帮助的答案
The touch panel and LCD screen of iPad can be separated and replaced respectively alone. You have open the touch panel, then remove the related screws and you can lift up the LCD screen easily(careful to release the flex connector.)iPad 4 Wi-Fi Teardown
And at last, you can place the new LCD screen. Remember to plug the connector tightly and check the LCD screen at the same time, also remember to replace with new adhesive sticker along the touch panel.
这个答案有帮助吗?
得分 1
2条评论:
Thanks alot for this! What about the home button? It seems in the teardown that it's a relatively delicate component, but in this iPad its ripped right out of the home button housing. Would I need a new ribbon cable for this?
完成的
The home button and flex will come with the disassemble touch panel, so you don't have to prepare another cable unless you break it. So take easy
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 119
