跳转到主内容
The Fosera Scandle 200 is a solar powered device that can be used as a lantern and/or a charging station for electronic devices.
2 个问题 查看全部
Why is my device not holding a charge?
I've had my device for a while now. Lately, it only works when plugged in.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
If your device is not holding a charge after a full charging cycle then your battery has likely reached the end of its lifespan. Rechargeable Lithium-ion batteries have a limit for the number of charging cycles they can go through, and as this limit is approached the battery will exhibit much a much lower capacity.
See heading "My device only works when the solar panel is attached" in the troubleshooting page at:
Fosera Scandle 200 Troubleshooting
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Vincent C 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 263
