跳转到主内容
The Nerf Vortex Vigilon is a single fire toy gun released in 2011 as part of the Vortex series, model number 32215. The gun fires XLR discs and is green, gray, black, and orange.
3 个问题 查看全部
Why is the trigger jammed?
My trigger will not move back when I try to pull it. It feels stuck and performs as if it has not been cocked.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
最有帮助的答案
The trigger could be jammed for two reasons. Either a disc is lodged in the barrel or there is dirt jammed underneath the trigger. In order to clear the lodged disc, pull the barrel slide located on the top right hand side of the gun with the gun barrel pointing down. The disc should be released and the trigger should pull back. To clear the dirt, you will need to take apart the gun. Clean the dirt with a toothpick or cotton swab. For more information, reference the Troubleshooting guide. You may also need the spring replacement guide.
这个答案有帮助吗?
得分 1
2条评论:
Did you copy this from Google?
完成的
@smitajaiswal
Look at the date of the post. You may be waiting a while for an answer
The link is to an ifixit guide created in 2014
Moderator
完成的
添加一条评论
添加你的答案
Cara Pew 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 26
总计 6,247
