跳转到主内容
The Canon Powershot A1000 IS features a lens with 4X optical zoom and a focal length of 6.2mm to 24.8mm and maximum f-stops of f/2.7 and f/5.6.
6 个问题 查看全部
I can't see any picture on my Display.
I can't see any search-picture on my display, the display itself may be o.k., because when I use the menu-button I See the menu on the display. When I start ! see the informations on the display. What can I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
newsforpeter, this can be caused by a bad CCD on your lens. Check the ribbon cables and make sure they are properly inserted. Also check for corrosion and debris damage. If all that looks ok you may need to consider either a new CCD or a complete lens.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
newsforpeter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 232
