跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2521 个问题 查看全部
问题已关闭
Will the front panel assembly from an iPhone 5s work on an iPhone 5?
Hi, I see that the i5 and 5S have the same hook ups and same size will a i5s front panel work on a i5 phone? also if not will the face glass and white bracket work with it using a lcd screen of a i5? also if these will work then will the i5S finger print Home button work with the other two if they work? I love the face plate of the i5S the Gold Ring. Looks like to me that the i5S assembly will all fit to the i5 bottom assembly just fine? all the same connections and should line up perfect, please advise i need a new front assembly and I'd like to make it pretty and if possible work better. Thank you all, Terry.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
no screen connections are different so the connectors will not fit.
and no the home button will not work iphone 5 uses gold contacts for home button to work as iphone 5s uses a connection.
you can how ever buy home buttons that make the iphone 5 look like a 5s
这个答案有帮助吗?
得分 1
1条评论:
ok, Thank you con.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 132
