screen broken but working
my tablet z touch screen broken, i want any professional guide to change a new screen.
check here https://www.youtube.com/watch?v=2DQpbjzK...
这个答案有帮助吗?
@kozzmic: That video only explains how to replace the full screen (LCD + glass + touch), not just the glass + touch. Seems you can buy the glass + touch digitizer without the LCD, and that makes the repair a lot cheaper, but maybe a bit more complicated: http://www.parts4repair.com/touch-screen...
Here's some insight on how to separate the glass + digitizer from the LCD. Looks like it's easy to do something wrong: https://www.youtube.com/watch?v=levTY6Ix...
:) check this surprise ,
change or replace the front glass only https://youtu.be/-nFy-Ojt8oc
这个答案有帮助吗?
Here's the teardown in full
My daughter just broke mine... Not amused atm
这个答案有帮助吗?
HI!
It's a pain in the ass to do this and i think this dont justify to have the job done.
I used two keychain rings attached in a piece of Nichrome wire because it's very hard to broke.
I heated a little all the tablet and put everytime direct heat in the part i'm with the wire and did the job with very very carefull.
after i thought the worst part is done, i've come with the loca glue removing. I think it's harder than the first part of removing digitizer from LCD. I used Isopropyl alchool and did it finally. but some alchool go to backlight and i can do nothing. The display is now blotched with alchool in some parts.
Conclusion: With very patience you can do this but i don't think it worth the effort.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 8,562
