跳转到主内容
Released in June 2013, the Galaxy Mega is a 6.3" smartphone featuring a 720P display, dual-core processor, and an 8 MP camera.
Why won't my Samsung galaxy Mega turn on after screen replacement?
I have a Samsung Galaxy Mega 6.3 SGH-i527 and I had the LCD screen/ digitizer replaced. After that the phone won't go past the Samsung galaxy mega logo screen, it won't go into recovery mode but will go into download mode. Any advice would be helpful, thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
6条评论
I have the same exact problem ant solutions?
完成的
I have tried the deal, boot with old screen then swap em out. My replacement still won't light up. Only thing I have seen work so far was just the back light came on, but still nothing else. Is there any other "tricks" to try?
完成的
You need to pull battery then power on with old screen and let it fully power about 10 minutes wait till the screen dims and goes off that's when you disconnect and after market one mines works every time. I have everything on the new screen I just pull the back cover and get my own screen Connect with ribbon power on and wait till it dims goes off then I just connect ribbon back being careful that I don't hit the power button or volume button just keep the screen off till you connect to my he screen. Works everytime.
完成的
Okay, I just tried this method and all I can get on the new screen is the back light. I do have a little trouble getting the flex to "clip" down. Could that be a problem? Or is it a defective screen? Too many questions, never enough answers...
完成的
Are you sure you have the correct model screen for your phone? Compare the new and old screen together make sure you check if the connectors are the same too
完成的
显示更多的1条评论
添加一条评论
12个答案
最有帮助的答案
You have to turn the phone on with the old screen still plugged up you then unplug the old screen while the phone is still on and you plug the new screen in and there you go it works perfect you just have to install it with the phone on
这个答案有帮助吗?
得分 3
2条评论:
Hey thanks it powered on just fine with the old screen then I just plugged in the new screen and it works! But will I be able to power off and back on????
完成的
So I have it powered on now thanks but my question is will it work after I power off or reboot or do I have to keep the old screen to boot it back up again?
完成的
添加一条评论
Go to eBay. & get the LCD/frame assembly. Then transfer ur parts over.
这个答案有帮助吗?
得分 1
1条评论:
I transferred over the LCD/digitizer and frame and after I put my battery in the phone turns on by itself shows the Samsung logo and shuts off I take out the battery again and it does the same thing it won't turn on at all please help
完成的
添加一条评论
Try to get root the phone to see if it's the problem of firmware.
这个答案有帮助吗?
得分 0
1条评论:
How can I do that?
完成的
添加一条评论
often, the screen was not meant for android 4.4, if your phone has android 4.4, the the screen may not be compatible wit it. I was looking for a replecement screen for my mega, but no luck finding one for android 4.4. That is probably the problem, but i cant help, sorry
这个答案有帮助吗?
得分 0
3条评论:
Thanks anyway
完成的
Hi.. im using mega 6.3 and its working perfectly but im just bothered because the four edges of my screen is overlapping from the phone itself.. for me it looks way more cooler because it has sharp edges than the roundy shape of the usual ones..but I just really want to know if my screen is normal or this is a replacement screen..thanks in advance..
完成的
My mega screen cracked i replaced it ...it was working fine then it turned off and wont come back on?? Can u tell me what might be wrong and os it fixable?
完成的
添加一条评论
Thanks man. It works. After two time new screen order for noting
这个答案有帮助吗?
得分 0
添加一条评论
My samsung galaxy mega wont start or if it does. It wont go past the samsung screen can anyone help me please.
这个答案有帮助吗?
得分 0
1条评论:
I am having the same problem IT want do anything it's just stuck on samsung screen please help
完成的
添加一条评论
hi I have a Samsung mega I changed the digitizer and screen it worked then went on to a warning then it shut down and now doesn't do anything it doesn't even charge
这个答案有帮助吗?
得分 0
添加一条评论
you need orginal screen to work in new version 4.4.2
if you can't find orginal lcd you can downgrade your software version to 4.2.2
这个答案有帮助吗?
得分 0
1条评论:
How do you downgrade if splash screen is all you can get and don't have the oem display? I'm at a dead standstill here!
完成的
添加一条评论
Hello I'm having the same problem. I switched. The lcd and the touch screen didn't work was that the lcd just wondering
这个答案有帮助吗?
得分 0
添加一条评论
Mine doesn't even work with the old screen. Still showed my background after the crack, then swapped it over and won't power on in either phone at all now. I fix a ton of megas and have never run into this problem until my personal one got destroyed....
这个答案有帮助吗?
得分 0
添加一条评论
I replaced only the digitizer on my mega 2 and it started freezing on the first menu, i am now trying the old digitizer and its still doing the same thing, any suggestions? I didnt feel the need to replace the lcd if it was still good
这个答案有帮助吗?
得分 0
添加一条评论
Seems that if you have a replacement screen in the mega it will boot loop solution is to power in with the old screen and after it powers on connect the new one and it works! Well done hats where I'm at now dunno if the phone will reboot again I haven't even attempted it yet! I'm letting the battery fully charge and hope fully I can install root and custom recovery! I have the mega i527 AT&A variant 6.3. So if anyone can link me to a working custom recovery for this model i527 I would really love appreciate it. Thanks a mil
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Tunyia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 9,184
