跳转到主内容
MacBook家族于2006年5月发布,替换了iBook来作为苹果消费级笔记本的产品线。
3786 个问题 查看全部
问题已关闭
PRAM Battery
Hi
I can´t find my pram battery on my macbook logic board 820-2279-a.
iFixit doesn't show my particular Logic board.
If someone could post a picture I'd really appreciate it.
Best Regards
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
It would help a lot if you specify which Macbook you specifically have. Check out our ID Your Mac page for steps on how to figure this out. Just the logic board # doesn't help very much.
完成的
添加一条评论
5个答案
已选择的解决方案
Use this guide for your PRAM. Apple moved the PRAM from under the logic board (where it was in Core Duo and Core 2 Duo) to near the right speaker (where it is in Santa Rosa, Penryn, and Early/Mid 2009). There is as cutout in these cases for the new location of the PRAM.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Here's the guide for:
If it is any other MacBook (Aluminium Unibody or Polycarbonate Unibody), ifixit do not yet provide the guide.
这个答案有帮助吗?
得分 1
添加一条评论
Looking at the guide for the MacBook Core 2 Duo (which is the early 2009 unit) it states in bold print the PRAM battery for that unit is not replaceable. Ralph
这个答案有帮助吗?
得分 1
添加一条评论
2 GHz (Early 2009) MacBook 13"
i have tried both guides but at the end i couldn'find the pram battery... its not located there it should be.... u think u can help me oit with that ?
thank you!
best regards//
这个答案有帮助吗?
得分 0
1条评论:
please see my post for your guide.
完成的
添加一条评论
The PRAM Battery in the Early 2009 Macbook is underneath the Optical drive, in between the Right Speaker assembly and the Bluetooth board. This placement was new for Early 2009.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 6,100
