跳转到主内容
The Microsoft Surface 2 was manufactured by Microsoft Corporation and is the second generation of Microsoft tablets. It was launched on October 22, 2013 and includes features such as upgraded processing power and screen resolution.
31 个问题 查看全部
(Plugged in, Not Charging) Error. Help?
I just bought a surface 2 last night and there is an issue, I plug in the power cable, but when I see the battery indicator, it shows "plugged in, not charging". The tablet turns off if I unplug the power cable..
I've tried the following workarounds that I found online:
1) shut down the tablet, unplug the power cable and leave it for few minutes, plug in back the power cable and let it charge for few minutes, turn it on.
2) shut down the tablet, press volume up + power button for 10 seconds, leave it charging for few minutes, turn it on.
3) Performed a full system recovery.
But sadly these didn't help. I would like to ask is there any other workaround I can try?
I have tried multiple outlets as well as multiple chargers.
Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 18
32条评论
I had this issue on my Surface RT after replacing the motherboard. After trying everything, this worked for me.
This was my last resort, I should've made it my first.
1- Exercise extreme caution!!! Keep RT plugged connected to the charging cable.
2- Using you're electronics tool kit, properly remove back cover and label the screws.
3- You may notice that while the battery is connected to the motherboard and you slowly move the back cover away, the battery is detected. If you experience this then my solution will work for you.
4- Cut three small pieces of paper and insert them on all sides of the curved connector. It seems that there is some kind of disturbance there and the paper will fix it. Message me if you need further instructions.
完成的
That's a crazy solution. I would suggest having Microsoft replace the tablet!
完成的
problem solved. All you have to do is plug cord in to computer before you turn on the power, or plug it in. Works every time!!!
完成的
sorry Barrygroom, that not a fix that works.
完成的
Well, Barrygroom, it worked for me! (Surface Book)
完成的
显示更多的27条评论
添加一条评论
11个答案
已选择的解决方案
I ended up finding a solution on a few forums. When the error massage (battery not detected) is showing in the desktop icon on tast bar, unplug the charger (tablet will shut off) hold down power button about 10 seconds and while still holding it plug the charger back in. When the surface logo appears let go of power button. That will then give you the "plugged in, not charging" message. Repeat the steps and it will eventually work. After it was at 45% i unplugged it and plugged it back in. It worked and was charging well but after unplugging and plugging back in several times i noticed sometimes it would not charge. It is just a matter of plugging in and unplugging the charger in my experience. Ive heard many other people having the same problem and getting around it doing the steps i suggested.
这个答案有帮助吗?
得分 26
26条评论:
That worked for me. Thanks
完成的
This worked perfect, Thanks for the post
完成的
Thanks man. I have battled with this for 2days now. It just worked
完成的
i dont understand when do u shut it down and when do u plug it back in im wandering because my tablet when i plug it in it just doesnt charge it first say pluged in not chraging then nothing else pls help
完成的
worked perfect ty
完成的
显示更多的21条评论
添加一条评论
hello,
Have you only a plug in symbol without the battery symbol ? please follow tha steps in this link surface-battery-wont-charge !.
if you done that and no result ,then is one of three your charge kabel maybe is broken or Check the connectors on both the power supply's connector and on the charging port (on the side of Surface itself) ! at the end of IS THE BATTERY ! IS BROKEN ! .
Please go exactly according to the instructions on the page!
and tell me about it if what needs to be repaired, I'll help you.
I'd bet more on the battery it is broken!
sorry for my bad english!
best regards, murrx
这个答案有帮助吗?
得分 3
3条评论:
Tried it and got a symbol with low battery, stays on for 3secs and goes off, the little light flickers and goes off... what should i do???
完成的
how do u know the battery itself is broken and not the internal chariging circuits?
完成的
i'm on my 4th charger now.. it seems the heat generated on the surface port and the charger connector plus dirt makes the plastic on the connector expand making the pins stuck up.. a regular connector is so much better than a magnetic one.
完成的
添加一条评论
Hi, I had this issue as well. After much searching and conflicting info (even on Microsoft site) I eventually found the answer.
Problem. Charger connected, right swipe showed power connected but empty battery. Unplugging charger meant Surface 2 RT shut down. Connect charger and power up, got repair message.
Solution that worked for me. Went into Device Manager (Search Device Manager), deleted the second entry under the Battery section. Shut down the Surface completely. Plugged in charger, waited 20 minutes and now there is a white line showing in the battery icon. Waited another 20 minutes and the white line is thicker - enough to allow updates to download and install.
As part of the problem solving over some hours, I had reset the Surface to factory default - which was probably not a bad idea anyway as a rebuild often corrects most problems (but not in this case). Hopefully this will help others.
这个答案有帮助吗?
得分 2
3条评论:
is there anyone who follow this workaround?
i afraid to delete ACPI section.
is it real???
完成的
worked for me on Nokia 2025
完成的
it worked on my surface 2. I bought it refurbished and once i disabled and deleted the second battery selection (2 listed exactly alike) it charged completely and finally allowed me to complete the firmware update.
完成的
添加一条评论
I got the same problem before
And I was plugging the charger plug up side down
and that was the reason when I return it to the right position the problem was fininsh
the lamp in the charger must be up and the wire down when you plug it to your tab
best wishes
这个答案有帮助吗?
得分 1
添加一条评论
Hi all,
I found that this was a bug related to the detachable screen. Have you tried to detach the screen? In case you have below 10% charge you can do it manually. Here is a video how to handle https://www.youtube.com/watch?v=4fVGQPQ3....
Once you have attached it back up try to plug in the charger and see if the status is changed back to "plugged in and charging".
Regards,
Bo
这个答案有帮助吗?
得分 1
1条评论:
This worked perfectly. I must have hit the DETACH key and didn't notice. A great solution would be for the DETACH process to auto-re-attach if it isn't removed in a certain amount of time.
完成的
添加一条评论
I have a surface pro 2.5 windows 10 with 2 charging issues
Issue 1. charger will light up for a few seconds then stop charging:
Cause: AC cord from wall to brick, I'm in the Philippines and I don't want to pay for shipping, easier to make or buy a new one.
My Solution: I had to shave the plastic and rubber parts of the male plug that goes into the brick so its in deep. I now get a steady charge light but after windows load i gets Issue 2
Issue 2. Plugged in Not charging:
Cause: windows 10 auto update of drivers (even if disabled, no go, it will still update)
My Solution: (temporary, still looking for a better one)
Before every shutdown, uninstall all battery and bluetooth drivers (device manager, put check on delete drivers) after shutdown, vol up + power button till it blinks twice(full shutdown), disconnect charger (don't power-up right away!).
Before power-up, reconnect charger and power on, on boot-up windows will auto install default drivers so the bluetooth and charger will work.
Once you go online new drivers will auto download and install and once restarted or shut, a full install will happen and you will again get the same issue. To avoid that I do the same said shutdown and power on procedures I formulated thru hours of trials and reading. Hoping that a new update will finally resolve this.
这个答案有帮助吗?
得分 0
添加一条评论
This site sucks...I filled out an answer but then was prompted to create an account. After creating my account my thoughtful explanation was nowhere to be found.
Anyways, in short, the internal battery connector on my Surface LTE is loose / disconnected. It would say it's plugged in, not charging. The light on the charger turns on, the screen brightness changes according to my power plan...the computer knows it's plugged in....but power just isn't getting where it needs to.
I just pressed on the back around where the power connector is and it instantly started working. When I open it up, if this is the case, I'll slip a few pieces of paper to keep the connector snug and connected so this doesn't continue to happen.
这个答案有帮助吗?
得分 0
添加一条评论
I just tried the below from https://windowsreport.com/detach-surface... and it then started charging battery 1.
To perform a two-button shutdown on your Surface Book, do the following:
Turn your Surface Book off.
After your Surface turns off, press and hold the volume-up button and the power button at the same time for at least 15 seconds, then release both (The screen might flash the Surface logo, but don’t release the buttons for at least 15 seconds).
After you release the buttons, wait for 10 seconds, and then press the power button again to turn on your device.
One you performed a two-button shutdown, try to detach your Surface Book from the keyboard, and it should work without any problems. In case you’re still unable to detach it, try some of the following solutions.
这个答案有帮助吗?
得分 0
1条评论:
okay so I have the Nokia Windows tablet. It is saying plugged in but not charging. I have tried the power off volume up battery reset also a hard factory reset. I've done a plug in while turn on. a shut down plug in unplug plug in power on and still nothing is working. Does anyone have any suggestions on something I can do to get it to hold a charge. Thank you in advance
完成的
添加一条评论
This is a alternate solution.
https://docs.microsoft.com/en-us/surface...
When battery limit is enabled in UEFI the surface with only charge to 50% If the surface charges higher then 50% then it will rapidly discharge the battery to 50%
This was my issue after a firmware update.
这个答案有帮助吗?
得分 0
添加一条评论
I recently brought one Surface Book 2. Got home only seeing 2 batteries both on 0 percent. At first it says not charging but later after some software update, not charging is gone but still had no way to charge it up. With it turned off and plugged in the whole night and both showing 0.
Looked around but not seeing any solution worked for me, i.e. 2 button reset , installed firmware update.
What works for me is that I looked up a way to manually detected the keyboard. (it is not that hard as someone mentioned will damage it as long as you follow a good guide on YouTube. This is what helped me. https://youtu.be/eZAVZClrNmM)
After detected the screen, I applied charger at the bottom of the tablet part and viola!!!! it is charging.
So my assumption is that the unit has been sit on the shelf for such a long time and the battery got completely drained. Using the normal way, charging through the dock/keyboard, is not working AT ALL.
I hope that helps!!!
这个答案有帮助吗?
得分 0
1条评论:
Had the same situation. Unfortunately the Keyboard still doesn't charge /its battery is not properly recognized (even after charging the battery by other means.)
So right now I have an overblown tablet...
完成的
添加一条评论
I went to device manage, chose batteries, right clicked on microsoft acpi and chose the scan for hardware changes option
the batter icon instantly shows thats its now charging!
hope this helps
这个答案有帮助吗?
得分 0
2条评论:
Really helpful Alexander, but sadly, no change on my end. All the drivers say they're up to date. Thanks anyway.
完成的
Same here. Considering how many users have battery issues on surface devices, it's pretty obvious that M$ have done a really shoddy job on the battery drivers.
完成的
添加一条评论
添加你的答案
Rush 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 62
过去 30 天: 247
总计 485,382
