Can I use RAM pc3 8500?
hi, i have this ram that i take it from a macbook unibody aluminium
RAM Upgrade / 1 GB / PC3-8500 / Low Profile / 204 pin, 1066 MHz
this ram is compatible with my macbook white?
thanks!
White MacBook "Core Duo" 1.83 13" Specs:
MacBook "Core 2 Duo" 2.26 13" (Uni/Late 09) Specs:
As you can see they are vastly different. PC2 and PC3 modules are not compatible (you can't switch one for the other either way). Sorry ;-{
这个答案有帮助吗?
The RAM standards folks have a trick to prevent you from using the wrong RAM: The slots in PC2 RAM sockets and in OC3 RAM sockets are in different places, so the only way to get PC3 RAM into a PC2 socket is through brute force. If you have to force something into a socket, that's a sign that you shouldn't be doing it at all.
thank you Dan
Tom:
No MacBook model A1181 ever used DDR3 RAM (they all used DDR2 667MHz or 800 MHz). You can check the specific type of RAM for your MacBook in:
这个答案有帮助吗?
Etrigan thanks
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 673
