跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Solve the Problem Red and Green Light in Magsafe?
Dear iFixit team
i got my MacBook in 2008 and am daily used
someday when i plugged the magsafe into my MacBook .. they doesn't charge it .
i put my battery in other MacBook and it's charge it fine ..
but in my MacBook doesn't working with battery (fully charged) until i plug the magesafe cable
and when am connected .. see what happen
http://www.youtube.com/watch?v=spAp0UwRw...
am open my MacBook and i check the magsafe and the connector of the battery ..
all of them its fine and working but the battery doesn't recognize and charge
so any idea how to fix that ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Contact Apple, tell them the problem and see if you're qualifies on the battery recall and/or magsafe recall.: http://www.apple.com/support/contact/pho...
Remove the battery and plug in the MagSafe and start up and tell us what happens with the light.
这个答案有帮助吗?
得分 2
4条评论:
am in arabic region .. there is no Contact for them .. that's why i asked there
完成的
You can contact Apple all over the world. Just pick the closest country from the list on this link: http://www.apple.com/support/contact/pho...
完成的
I feel that "call Apple" isn't really in the spirit of a website about repairing things.
完成的
Well Ross, when there's a recall on something and you choose to ignore it...........
You can't fix stupid.
完成的
添加一条评论
Your machine is to young for a problem like that, you may need a new I/O board replacement. For now, make sure that the power adapter connector is free of any type of debris matter and that those small contact pins are not distorted in any way. Remove the battery prior to working with the AC adapter pins on your Macbook Pro and DO NOT use anything that might mess up that magnetize feature.
这个答案有帮助吗?
得分 0
添加一条评论
I've tried replacing the I/O board on a macbook pro with this exact problem, and it didn't resolve the issue. It was a relatively inexpensive and easy repair that seems worth the chance.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tariq Zahraa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 5,596
