Backlight not working, turning off after a few seconds
Hi
Recently I bought a second hand macbook air that had coffee spilled on it. The owner replaced the battery, and it was working again like a charm. Now after a few months of my ownership, I turned the macbook on, but it had no backlight. Also the macbook turned off in about 5 seconds.
The weird thing is, i've owned this macbook for about 5 months now, and it always worked great with no problems at all. Could this still have anything to do with the spill on it? I searched alot on the internet already, and the fuse with the 'p' on it still seems fine, as no coffee seems to have gotten to that part of the logic board. I will try to upload some pictures of it ASAP.
Thanks in advance.
7条评论
Daan, it "seems fine" with a multimeter as well? Changing the battery after the spill was a good step, but I would have suggested a good cleaning as well. Take a good luck at the LED driver and see what you find.
由 oldturkey03 完成的
Hello oldturkey03, thanks alot for your reply.
I haven't checked it with a multimeter, as I don't really know what the multimeter is supposed to 'say'. Do you know what it should say?
Also, where can I find the LED driver?
Sorry for my terrible English, as it is not my first language.
Thanks in advance :)
由 Daan 完成的
Daan, your English is just fine ;-} Your just facing a lack of skills which we can help you over come.
由 DanJ 完成的
Thanks Dan. :)
Update: I cleaned the whole logicboard with isoprophyl alcohol, im now going to put everything together. I will let you guys know what will happen.
由 Daan 完成的
I put the whole thing together and still no back light and turning off right after the login screen. I made some progress though. It seems when I unplug the flat cable that goes from the I/O board to the logic board and turn it on, it does have a backlight. The only thing that appears on the screen is some kind of suitcase with a ? in it. So this basically means the fuses and LED driver aren't dead yet, right? I'm going to order a new cable tomorrow so i'll keep you guys updated.
由 Daan 完成的
显示更多的2条评论
