跳转到主内容
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 个问题 查看全部
Dropped my Ipad and now my touchscreen isn't working right
I recently dropped my iPad 2, and at first it was fine. Then, I noticed the touchscreen kept freaking out as if I were scrolling it left to right continuously. Eventually, it started clicking on things by itself and now I am unable to even click from the middle of the iPad all the way to the left. The panel is cracked pretty bad at the top of the device, could that be why my touchscreen is malfunctioning? Or is it something else?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
最有帮助的答案
Sounds like you need a new digitiser. That sould solve your problem. Plenty of tutorials for it if you want to tackel it yourself, just take your time. :)
这个答案有帮助吗?
得分 4
1条评论:
Thank you for your help! I looked it up and it sounds like that's the problem to me too.
完成的
添加一条评论
Chances are there is also a dent in the case of the iPad. The odd behavior you are describing is ghost touches on the screen. Unfortunately its nothing cool like a poltergeist has possessed your tablet and you will now be able to move objects with it. It just means that something is pressing up on the screen, causing the digitizer to misbehave.
Luckily its a very simple repair. I highly recommend taking it to a reputable local repair shop to have the repair done. It will take them no time and your iPad will be as good as new.
这个答案有帮助吗?
得分 1
1条评论:
well ghost touches are impossible as the ipad is supported with heat as touches well y know what i mean
完成的
添加一条评论
You know this is illegal to carry a cracked ipad, because apple doesnt want to look bad.
这个答案有帮助吗?
得分 0
1条评论:
how does it make apple look bad? its the buyers fault
完成的
添加一条评论
添加你的答案
Kelsey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 1,992
