跳转到主内容
完整的拆卸和安装指南,支持大部分的 iPods, 包括 iPod original, mini,shuffle,nano,classic 和 touch。
7429 个问题 查看全部
iPod Nano wont sync to itunes
I recieved this iPod nano 4th generation as gift. My friend said she bought them from Hong Kong. But I can not get this iPod to sync songs from my itunes. The itunes does not even reconize that the iPod nano is even there. Or it will act like it has synced the song and when you turn on iPod nano it says empty disc
Thanks
Tracy
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个回答
已选择的解决方案
well, there is one tiny thing that comes in my mind when ir read "iPod nano" and "hong kong" - it's most likely not even an iPod.
does the computer shows the "iPod" when you connect it?
how does the folder structure looks like?
这个答案有帮助吗?
得分 1
添加一条评论
Yea this sounds like it's a cheap knock-off. Turn you'r "iPod" over and read the serial number and put it into the apple site to see if the serial number (if there even is one) is valid in the apple database.
Input the serial number into the applecare warranty page on the Apple site below, if the ipod is a knock-off then the serial number wouldn't be valid in the database.
https://selfsolve.apple.com/GetWarranty....
这个答案有帮助吗?
得分 0
添加一条评论
ihave one too i just got. and it syncs to the computer like charges but when you bring up itunes it wont connect. it isnt a valid serial number either. but i mean to be honest it still should work. its made in china and im sure if people buy them and use them there then they should work. why shouldnt it?
这个答案有帮助吗?
得分 0
评论:
the reason for that is because they are look alikes, called Chipod. They do work as an MP3 player but are not usable with itunes. Do a Google search on it. There is a way to identify those by the firmware ver.number.
完成的
添加一条评论
my ipod nano 2nd gen actualy connected and its not a knock off but i stopped using it for like 7 years and then came back to it it connected to itunes for the first couple of days but then it just stopped.any ideas in how to fix it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tracy 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,694
