跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
914 个问题 查看全部
问题已关闭
Do I need more glue/adhesive to reassemble the display assembly?
I need to disassemble my iPod touch 4th Generation to tighten a couple of screws around the headphone jack. You need a heat gun to soften the adhesive to remove the display assembly. When I reassemble it, do I need to add more adhesive to stick the screen back on? Will the original adhesive still be sticky enough to glue the screen back on? Do I need to heat the display assembly again? If I need more adhesive, will sticky double sided tape work? Would I need to remove the original adhesive, and how would I do that?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Sometimes it will work, but i usually use some goofoff to take old adhesive off and use the new adhesive that comes with the screen
这个答案有帮助吗?
得分 0
添加一条评论
As it's not a new screen goin in, you can buy the adhesive online for pennies.
I wouldn't re use it, especially with the little ammount used at the top.
but what I did use for my own as a trial was silicone, its flexible still not brittle, and is easy to remove if youneed to open it up again. And it's not lifted in the year that ive had it.
Im talking a small ammount applied with the flat head screw drivers you get with the kits.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 136
