跳转到主内容
The Dell Latitude E6400 was Dell's mainstream corporate 14.1" notebook introduced in August 2008.
40 个问题 查看全部
问题已关闭
middle LED diagnostic light blinking during POST, change LCD?
After powering on Dell Latitude E6400, the hard drive will start but then everything shuts off and the middle LED diagnostic light begins to blink. I have swapped LCD cables but problem persists. Is replacing the LCD screen a viable solution?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Mike Jones, the "middle" light blinking indicates a RAM Memory Fault. Possible solutions are
-Reseat the memory sticks.
-Replace the memory sticks.
-Replace the motherboard / system board.
Get the service manual for your computer from here. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
I wouldn't think so. If the LCD was just out you should still hear windows boot up, fan should still be going and so forth. If the screen never comes on and its shutting down before windows tries to load my first guess would be MB issue.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,858
