跳转到主内容
修复你的物品
维修的权力
商店
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1512 个问题 查看全部
问题已关闭
I replaced my dock assembly, why won't my iPhone connect to pc?
whenever i plugged in my iPhone the computer said usb device has malfunctioned. i "googled" around for solutions and found i needed a new dock assembly. so i purchased 1 and installed it but now my iPhone still wont connect help please
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
My iPhone would charge but there was no sound or lightning bolt when i plugged in in apart from 1 usb but i had the usb device not recognised problem. i changed the dock assembly and now ehen i plug it in there is no response from the iPhone or the pc. i havent checked if its charging should i let my battery drain to test for charging and then report back?
完成的
you don't need to discharge it completely - only enough to see the difference
完成的
well when i plug the turned off iPhone to the pc it turns on but ill check for charge asap
完成的
I discharged it an recharged it but when it's charging there no lightning bolt in the corner or "bleep" when i plug it in
完成的
do you still have the old dock assembly ? i would put the old one back into the phone - maybe the new one is faulty!
完成的
添加一条评论
3个回答
does it only not connect or do you still get the power surge error ??
if you still have that problem - open the phone again and check it for possible fluid damages, shorted or burnt parts..
这个答案有帮助吗?
得分 0
评论:
How will i know if parts have shorted?
完成的
if there was a fluid damage, you should see some white/greenish residue, but if it was some "colored" fluid - it could also look different (like the MacBook i bought on ebay with a blue curacao damage - everything was blue and sticky)
完成的
添加一条评论
Before replacing the dock did you try connecting to a different PC I have had that error with a number of devices but it was caused by a faulty USB port.
这个答案有帮助吗?
得分 0
评论:
I tried on a friends pc and some macs in an apple store
完成的
添加一条评论
I didnt see anywhere where i can comment or ask a question so i'm just putting it here. I was wondering if you ever found a solution to this darby? I'm having the same problem so i got a new dock connector and the problem persist. If you've made any progress please please please let me know!!! Thank You
这个答案有帮助吗?
得分 0
评论:
i did not make any progress as i couldnt be bothered to buy a new connecter from ebay just in case that doesnt work either. if i do end up buying 1 and progess is made i will reply with my results
完成的
添加一条评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 2,051
