1.7 GHz dual-core Intel Processor (Turbo Boost up to 2.6 GHz) with 3 MB shared L3 cache
109 个问题 查看全部
magsafe powering computer but not charging the battery
After mild liquid (cat pee) damage near the left (charger, USB, headphone jack) side, magsafe light will not come on.
The computer shows the charger icon with no "lightning bolt" and the battery says 0%. It appears to be getting power from the charger, since it has not died even though it's been a couple of months since this happened.
The USB and headphone jack work.
At the genius bar, they opened it but would not fix it once they saw it was gross liquid damage. They did not say where the damage was (or I didn't hear it).
Otherwise the computer works perfectly. Do I need to replace the left I/O board? (the charger works on a different mac). Any guidance would be much appreciated.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 1
评论:
I am interested to hear what you came up with. I have the same issue that you're having. I didn't have any water damage though. The system information still lists my battery condition as normal. I ran the apple diagnostics, did a SMC reset, everything, and still no light.
That said I have yet to try another charger. Did you get a replacement battery? Did that fix it?
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
That would be a good place to start... you may also need a new battery.
Carefully cleaning the logic board of any corrosion would also be wise. as corrosion worsens over time, and bridging may occur.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
Swerve 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 7
总计 375
