跳转到主内容
苹果的外置光驱,本质上是MacBook Air SuperDrive的重塑。
35 个问题 查看全部
What's the model number of this version of SuperDrive?
The latest Apple USB Superdrive, MD564ZM/A Model A1379, doesn't have the PATA connector for the internal slot-in optical drive. It's soldered to the USB wire directly. Therefore it's very difficult to replace the internal drive.
What's the model number of the superdrive shown in this repair guide, please?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Hey, so better late than never I guess. I'm pretty sure the original USB model is A1270.
That's a %#*@ shame about the USB connector being soldered straight to the drive here, I was hoping for a SATA connector.
这个答案有帮助吗?
得分 0
添加一条评论
The connector is hidden under the circuit board. Any drive that matches the size, is supported by OS X and has the PATA connector should work. Once you get yours out you should see a manufacturer's sticker on it.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 -1
2条评论:
Thanks for the message, machead3! The model you show here indeed has a circuit board that attaches to the optical drive itself. The latest model I just bought doesn't have such a circuit board. The wire coming from the USB goes straight to the circuit board of the optical drive at the same spot the connector usually is. So no connector at all. I am therefore looking for older model that has the circuit board exactly as what you posted.
完成的
this is incorrect, only model A1270 (manufactured prior to 2012) has a PATA connector hidden under the circuit board.
完成的
添加一条评论
添加你的答案
bko 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 15
过去 30 天: 42
总计 5,914
