跳转到主内容
The Roomba Red 4100 is a vacuum cleaner robot produced by iRobot that can clean a room all on its own.
12 个问题 查看全部
问题已关闭
I want to use it in UK
I have just been given a used Roomba Red 4100. I can't test it, as the voltage is different from the UK (ours is 240) and of course the plug is different. Various sites have said you shouldn't just use an adaptor for the plug. Does anyone know if it would be safe/sensible to try it here?
Many thanks,
Lynn
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Input Volt Range: 100-240V (Worldwide Compliant) Output: 22.5V 1.25A /
http://www.amazon.com/Adapter-Battery-Ch...
这个答案有帮助吗?
得分 1
1条评论:
Thank you very much. I have that with it. I'm not an engineer and probably shouldn't even be here! So you reckon I can find an adaptor to UK plug and won't explode?
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 82
