跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
223 个问题 查看全部
LCD now white after screen replaced.
I replaced my broken digitizer and now the LCD is white-before it showed only the battery powering up. i was ultra careful, and had no trouble with the removal of all the parts/LCD. cant see any obvious problems, have tried reseating connectors.
is the LCD knacked or is it a loose connection?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
had tried the DFU thing. no response. the iPhone isn't being recognised. am going to try a new screen so i can see what's going on and then go from there. cheers.
完成的
replaced lcd and now all is well with the phone. obvioiusly not as careful as i thought....
完成的
添加一条评论
2个答案
已选择的解决方案
这个答案有帮助吗?
得分 0
添加一条评论
I have an anwser for you you need to crash your phone! here is a link on what to do. In this video it tells you to put in your own ipsw. That is a file containing the version of your phone ei. 3.1.2 or. 1.1.1 you get my drift you can find these files on the internet. So without further adue here is your link for the videohttp://www.youtube.com/watch?v=3_mwOuK4c...
Okay sorry before you try what I wrote up top try this.
>put your phone in dfu. hold both the power button and the home button together for ten second, then release the power button but keep holding the home button for another ten seconds.Do all of this while it is plugged into your computer, and itunes is on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pollytintop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,526
