跳转到主内容
The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
125 个问题 查看全部
Why tablet is doen't recognize the device?
Hi...
My tablet is charging when I m connect the data cable in to the USB port.But My laptop/PC doesnt recorgnize it a device..I cant access my tablet in my laptop..Can any reply to me..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 12
2条评论
Bought a note 3 on ebay, with the same problem..bought the data cable..nothing. Device mgr shows the phone and has drivers from Samsung listed in the usb listing. cannot transfer music....any help out there?
完成的
My Samsung Tab SM-T210 can connect to Computer thru micro usb port but a usb flash drive cannot be detected, what should I do?
, pls help.
完成的
添加一条评论
5个答案
已选择的解决方案
Has it been recognized before?
What operating system (computer are you using)?
Does it charge it, even though its not recognized?
I would check to make sure you have the correct drivers installed and that you are using a data transfer cable, although the cables may seem to be a like some are not capable of transferring information and are meant only to charge the device.
Post back so I can further assist you.
Have a great day!
这个答案有帮助吗?
得分 10
15条评论:
Thank u for the answer..
yes. It was recognized earlier & computer OS is windows 8, yes it charge even though it’s not recognized. I think drivers are fine. Its working before correctly. I can’t find the problem is whether cable or my PC..
Thanks. Have a great day!.
完成的
Reply, Henry
完成的
The other idea that comes to mind is there are USB options, ensure "Media Device (MTP)" is checked. You can find this when you drag your finger from the top of the tablet. Should read " Connected as a media device Touch for options" tap that.
If the previous does not help you I would try changing the cable out, if you have one available (sometimes they go bad).
The last thing I would do is open device manager in windows 8 and remove the drivers then download them and install them from the vendor themselves.
On the desktop, press Windows key + X and select Device Manager.
b. Check if the Tablet is listed.
c. If it is listed, then right-click on the device and select Properties.
d. Check if the device is working properly.
完成的
Did you recently update to 8.1? Also what version of Android is the tablet running? What version of Kies do you have installed? (Kies and Kies 3) If you have time download the appropriate version then install and restart the pc.
http://www.samsung.com/africa_en/support...
完成的
Did any of this help or do you still have the issue? If you could post back to help others that would be very nice.
Thanks in advance,
Henry
完成的
显示更多的10条评论
添加一条评论
Pretty rude of OP to not respond.
这个答案有帮助吗?
得分 0
添加一条评论
, pls help.
这个答案有帮助吗?
得分 0
1条评论:
Wow, the Q & A on this is complex. I bought a micro USB to USB hub for my tablet. I don't care about charging. I just want to plug in a keyboard and a wireless mouse to the hub. When I plug the hub into my tablet and plug in the USB for my mouse, nothing at all happens. I flip the switch on the back of the mouse. Still nothing. It doesn't even recognize the keyboard is plugged in. Any advice for this scenario?
完成的
添加一条评论
Wifi direct to your phone. . Send files. Then phone to PC with USB.
这个答案有帮助吗?
得分 0
添加一条评论
However, there is nothing said e-tablet is not listed in the device manager screen!!!???
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lakshika 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 51
总计 90,813
