跳转到主内容
发售于2014年春季 的一加 一拥有着5.5英寸的显示屏 运行着基于Android的CyanogenMod 12S操作系统。
110 个问题 查看全部
Proper One Plus One Display Replacement
Hello @ifixit , is there a more step by step process to replacing the screen? I have the replacement screen (LCD + Digitizer Piece) and I have seen the break down, but how do you put it back together exactly? if I just disconnect both of the screen connectors, would I be able to use the iopener to remove the screen,or do I need to remove the other components? also after you remove the screen with the iopener? Is there a proper way to attach the screen back? what kind of adhesive to use. thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
17条评论
Hi Mikel,
I broke my screen few hours ago. Can you tell me where you found your screen replacement ?
And did you managed to replace the screen ?
Thanks
完成的
This is is the screen I got, there were only a few options online. I should receive it next week and will comment on the quality then. thanks
http://www.aliexpress.com/item/Original-...
完成的
Someone told me it comes with adhesive already so I should be good to go next week. I already know how to replace the screen from studying the breakdown. I will probably do my own how to video.
p.s. I also ordered a ifix it kit for taking some of the pieces off.
完成的
I disassembled my OPO yesterday watching the teardown. It was easy for the battery and all other back stuff. I tried to remove the screen and that was a fail. My glass is broken but the LCD seems fine.
I'm about to order this one since yesterday, I'll wait for your feedback then.
完成的
ok, I am expecting it in the next couple of days. what did you use to remove the screen?
完成的
显示更多的12条评论
添加一条评论
8个答案
最有帮助的答案
@Dev Mikel, Hi sorry I can't answer your question, but can you advise where you got the screen assembly from, & maybe comment on quality once you have it installed.
Thanks
这个答案有帮助吗?
得分 1
2条评论:
完成的
My friend recommended this shop which can offer one plue one lcd screen replacement . I want to buy from them but I don't know if it works well . http://www.dragon-tt.com/xx.aspx?id=3867
完成的
添加一条评论
How much does OPO charge to replace LCD screen?
这个答案有帮助吗?
得分 0
3条评论:
OPO was charging me $335 to replace the screen. Their customer service is horrible, they sent me a defective product and they're refusing to replace it through warranty. Might give this a shot myself and see how it goes.
完成的
it is better to do it yourself, only cost me $128 total to replace my screen...
完成的
For the repair services for your OnePlus One, the price will be as follows:
Touch Screen EUR 132
Repair cost EUR 15
Total EUR 147
完成的
添加一条评论
whats weird is for motherboard, they charge 230 EUR
for screen 132 Euros
for the phone - 300 EUR!
WHy the fcuk do they do that?
这个答案有帮助吗?
得分 0
添加一条评论
Dev, did you successfully change the screen already and if so, did you make a video of it?
这个答案有帮助吗?
得分 0
4条评论:
hello, yes I was successful in replacing the screen. If you follow the break down steps its pretty easy to put back together. if you have any questions fell free to ask. (I would say just watch the slip at the top that holds the touch digitizer cable in place at the top of the motherboard). I wasn't able to make a video because I wanted to open it and see what I was dealing with but after I opened it, it was too late and I just proceeded to following the steps.
完成的
Hi Dev,
How was the screen you purchased from Ali express?
完成的
Yes... Can you please comment on the seller and quality of his product please
完成的
See my comment above, rather pay a little more and buy from a more official source. The seller on AliExpress isn't trustworthy and refuses to refund/replace me for a cracked screen I received.
完成的
添加一条评论
And tbh I dont really understand why you have to take apart the motherboard before taking the screen out. Is that really the case and if not, then this is a piece of cake.
这个答案有帮助吗?
得分 0
1条评论:
well for me i had to take all the components out because my screen required heat to remove from the midframe, otherwise you risk damaging the internal components if you dont take them out first.
完成的
添加一条评论
Hi I want to repair my touct screen
这个答案有帮助吗?
得分 0
添加一条评论
I want to repair my oneplus one touch screen
这个答案有帮助吗?
得分 0
添加一条评论
Hej guys,
This was my first repair ever and I have to admit it was a lot easier than I tought.
I used the teardown guides combined with the youtube videos and managed to make the whole proces in less than 2 hours. It looks like its gonna take forever but its the opposit than lego. Building it up takes 5 minutes.
The only problem I had was that 1 screw was broken. I had to screw right through it with a drill. Luckely I didnt touch any important stuff.
The screens you buy on amazon or on aliexpress are not the legit ones, you see it at the quality of the screen and the onscreen buttons dont lit.
But to be fairly honest it is worth the effort. I paied 65€ for a screen with toolkit.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dev Mikel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 31,357
