跳转到主内容
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
179 个问题 查看全部
How you change serpentine belt
Cerpintine belt
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
Troy, this is what the manual says :"
2.4L
REMOVAL GENERATOR AND AIR CONDITIONING BELT
(1) Raise vehicle on hoist.
(2) Remove the drive belt shield (Fig. 8).
WARNING: DO NOT ALLOW DRIVE BELT TENSIONER TO SNAP BACK, AS DAMAGE TO TENSIONER AND/OR PERSONAL INJURY COULD
RESULT.
(3) Position a wrench on the belt tensioner lug (Fig. 3).
(4) Release belt tension by rotating the tensioner clockwise (Fig. 3).
(5) Remove belt.
(1) Carefully return tensioner to its relaxed position.
POWER STEERING PUMP
(1) From top of the vehicle, loosen locking nuts (1) and (2) (Fig. 4).
(2) From under the vehicle, loosen the pivot bolt
(3). Loosen adjusting bolt (4) until belt can be removed.
(1) Install belt onto all pulleys except for the
crankshaft (Fig. 5).
(2) Rotate belt tensioner clockwise until belt can be installed onto the crankshaft pulley (Fig. 3).
Slowly release belt tensioner.
(3) Verify belt is properly routed and engaged on all pulleys (Fig. 5).
(4) Install drive belt shield (Fig. 8) and lower vehicle.
DRIVE BELTS - 3.3/3.8L
REMOVAL
WARNING: DO NOT ALLOW DRIVE BELT TENSIONER TO SNAP BACK, AS DAMAGE TO TENSIONER AND/OR PERSONAL INJURY COULD RESULT.
(3) Position a wrench on the belt tensioner lug (Fig. 9).
(4) Release belt tension by rotating the tensioner counterclockwise (Fig. 9).
(5) Remove the drive belt (Fig. 10).
(6) Carefully return tensioner to its relaxed position.
INSTALLATION
(1) Route and position the drive belt onto all pulleys, except for the crankshaft (Fig. 10).
(2) Rotate belt tensioner counterclockwise until belt can be installed onto the crankshaft pulley (Fig.9). Slowly release belt tensioner.
(3) Verify belt is properly routed and engaged on all pulleys (Fig. 11).
这个答案有帮助吗?
得分 6
1条评论:
Not the answer I wanted to hear, but a good and accurate answer. I sure wish I had that hoist!
完成的
添加一条评论
New belt appear to be 3/4 inch short ( tight ) will not go on.
这个答案有帮助吗?
得分 1
添加一条评论
These vans have a reputation for the tensioner refusing to release. In any case, do not underestimate the torque required-- and in a direction opposite of that needed to put belt over crank pulley.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Troy 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 94
总计 33,939
