跳转到主内容
Apple的 MacBook Pro 的產品線是專為可望極致效能專業使用者所打造。MacBook Pro 产品线包括了MacBook Pro 13" (一體成型機身款), MacBook Pro 15", MacBook Pro 15"(一體成型機款), MacBook Pro 17" 和 MacBook Pro 17" (一體成型機款)。
20000 个问题 查看全部
Won't burn DL DVDs anymore
After successfully recording somewhere around 15 Double Layer DVDs on my MacBook Pro over a lapse of 6 months, I have not been able to record them anymore.
Using the same brand of media I used earlier with success, the drive now throws some sort of "Media Error" message when somewhere like the middle of the recording process and just aborts the recording.
I think I might have spent more money on spoiled DL DVDs than a new Superdrive's worth.
Is there something I might try to do that might fix this? Or should I just go and disemburse $129 for a new drive?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
已选择的解决方案
You could try one of those drive cleaning discs with the little brush on them, or spraying some compressed air into the slot - in case there is some dust interfering with the lenses.
There are multiple lasers for reading and writing the various media (CD, DVD, DVD-DL).
But this sounds like a laser has failed in the optical drive - if it is still under warranty, I would take it to Apple for repair. If not under warranty, it might be more cost-effective to get an external burner.
这个答案有帮助吗?
得分 3
1条评论:
Hi David, thanks for your comments.
Yes, it does record DVDs and CDs normally. Not so with DL DVDs, it's the only thing it does not seem to be willing to do anymore.
I already disassembled the unit and gave it a good cleaning with compressed air; next step before inquiring into any expense will be to clean the lens with a special solutions I have for cleaning CCD sensors in my Digital DSLR Nikons.
Hope this works, if not it is definitely a hardware failure. Warranty expired one month ago, curiously enough, precisely one year after purchase...
Will keep you posted on any development.
The external burner is a definite GO, specially considering the availability of Bluray units...
Regards and thanks again.
完成的
添加一条评论
Sound's like a problem with the media however, does it work fine on a regular or any other CD/DVD?
这个答案有帮助吗?
得分 0
添加一条评论
Any chance you've gotten stuck with a bad batch of DL DVDs this time 'round? Have you tried to burn these DVDs in a different machine or tried a different brand/batch in your current machine?
这个答案有帮助吗?
得分 0
添加一条评论
Definitely a bad batch of DL DVD's, it burns other disks fine, so it is definitely the DL DVDs, sucks, but they're pretty much worthless looks like. Try to store them in a not-so-variable and stable environment.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for your advise Mister790. Anyway, I don't think the problem might be the DL DVD batch I bought. I also tried with Verbatims to no avail.
I think it is definitely a Hardware issue...
完成的
添加一条评论
添加你的答案
mmontalbetti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 4,409
