跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
问题已关闭
Why can't I turn the iPhone 5 on?
It was the first time to open my phone. I was going to replace my battery, but when i tried to separate front case, I could not arrange the force and I could not control it. I think the cables between front case and back case got damaged a little bit. Later I replaced the battery and I closed it. But the screen is not working. I plugged the phone to charger it overheats and makes kind of warning sounds in every 2 or 3 second. I checked from itunes it is getting charged but not any sign of light in the screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I think the cables might be damaged a little was the correct guess!
The bonging noise indicates the screen is damaged you will need to replace
这个答案有帮助吗?
得分 1
1条评论:
Thank you. I opened it further more and came to the same conclusion. Because the cables are damaged too.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 74
