跳转到主内容
华为产品的维修和拆解指南
1885 个问题 查看全部
My Huawei Ascend Mate MT1 U06 wont't turn On or charge :(
It is like 5% left on my battery and i charge it with a (samsung galaxy y) charger and after an hour its dead. :( what's the problem of my phone maybe its the battery :(( Please kindly help me thank you .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
is it possible you don't charge it enough? Because it may show 100% battery but in fact be 15%?
Because its a common system error in android.
Of course it also could be that the batter need to be replaced, how long have you had your phone for? Has the battery looks the same size to you because sometimes it expands for some reason and just doesn't charge
这个答案有帮助吗?
得分 0
3条评论:
I have my phone for about 8 months now, the battery seems okay but i think that the charger drain all the energy from my battery and that's why it won't turn on or charge., Is it possible?
完成的
Its not possible for the charger to drain energy from your phone the mains won't allow the charge to reverse its direction of electrons flowing through, the charger might however short circuit - its where the charge has chosen the shortest, least resistant path, and therefore the phone won't charge and the charger is broken.
However the issue of battery being drained when charging may only be possible when charging via USB port not and the a/c adapter.
I have two options what might have happened, either your charger is faulty or its a loose connector in the phone itself.
Have you checked the warranty? It maybe worthwhile to check whether it covers the issue you are dealing with.
完成的
Okay, Your response is such an honor to me aleks, thank you. I'll try to check it to the store where i bought this phone.
完成的
添加一条评论
Hi there,
MY Ascent Mate 7 is off( like for good and all), i am trying to charge it but no sign that it's charging.
No signs of life :(
Any help, fellas ?
这个答案有帮助吗?
得分 0
添加一条评论
Hi,
I have bought a Huawei ascend mate, it would not charge or turn on, have replaced charging port and battery. Still will turn on or charge.
klem
这个答案有帮助吗?
得分 0
添加一条评论
My huawei mt1-u06 signal network down for six weeks How do i fix the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kim Brylle 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 11
总计 3,627
