跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
SIM reads after bat. death, then doesn't.?
I recently dropped my iphone in water. I took it out immediately, and got it in rice. After letting it dehydrate for two days it works, but it gets no signal. It was like this until I let the battery die. I charged it back on and had signal, but after some time it said No SIM. Also sometimes doing a soft reset will make it work for a little too. Currently it just says Searching... Help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Rice don't work you phone it doesn't get rid of the corrosion that occurs when the water drys it needs opened up and cleaned with ISO alcohol then recheck the phone.. If still no signal change the dock and if still no signal then it's a board problem.. That's what u get when you dry it out or use the magic rice it just don't work
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nuggetteer 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 4
总计 55
