Wired internet access RJ45
How to fix or replace the part for the wired Internet access using RJ45.
the yellow LED does not blink, the problem is in the laptop. Is it a module to replace to fix the problem?
Thanks
David, Check your settings. Check to make sure the LAN port is enabled
Click-->Start
click--> control Panel--> then Performance and Maintenance
Click--> System icon -->Hardware tab-->Device manager button
Select the appropriate network adapter
Click--> Actions--> select Properties icon
Select Use this device (enable) check box and click OK
Hope this helps, good luck.
这个答案有帮助吗?
Thanks for your suggestion, but I did not find more than one adapter, the Intl wireless adapter.
Try to download the drivers for your computer from Toshiba and see if it can find the adapter. If it does not you may have issues with your mother board. Worst case scenario you may have to use a USB to ethernet adapter.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 127
