跳转到主内容
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 个问题 查看全部
Port/Mother board is corroded, can I repair this to salvage my phone?
My Galaxy S III stopped working. It would not acknowledge being plugged in beyond flashing a quick "charging" picture, though never charging or lighting up in the corner. I placed a fully charged battery in the phone and beyond flashing "samsung" across the screen it would not turn on. I took it into Sprint and they showed my that the port on the mother board was corroded and that this would need to be replaced. Prior to ordering a new motherboard, which my husband would be able to do the technical work to replace it, I was wondering if it is possible to clean the corrosion and still salvage my current phone?
https://lh6.googleusercontent.com/-mrzLX...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
You could clean the corrosion off the motherboard by using a tooth brush and isopropyl alcohol but by the look of the damage it's probably best just to replace the charging block as there isn't much damage on the actual motherboard only the part.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jessie Foster 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 192
