跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1234 个问题 查看全部
Water soaked iPhone 5c won't power up
iPhone battery not showing any voltage. When I plug in the lightning cable, can't read any voltage at the battery connection socket on the charging board.
Questions:
Should the display show the Apple logo when I plug in the lightning cable even though the battery may be dead?
Should I be able to measure voltage at the connection socket on the charging board?
Are there any other test points where I can measure to determine that the charging port board is faulty?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
When iPhone's are plugged into the mains they do not need battery life for them to show the Apple logo, so you should be seeing the Apple logo when it is plugged in. This means that the phone is not recognizing the lightning cable, try a new cable. It is a common fault on all of the iPhone 5 series that the charging ports go I replace too many a day/week so I would suggest just replacing the charging port as it's most likely to be that plus they don't cost too much.
这个答案有帮助吗?
得分 0
添加一条评论
Sara not really the case...
First off if it was water damaged did you clean the board for corrosion?
9 times out of ten the battery needed replaced and if battery is dead and is still connected to the battery connecter it will not show and apple logo until the battery is removed from the connector
这个答案有帮助吗?
得分 0
1条评论:
Thanks SaraMai and Con.
Tried to power it up with the lightning cable with the battery unplugged, no logo. Was able to test the lightning cable by charging another phone.
Will remove and check the main board for corrosion before installing replacement parts. Have ordered replacement battery and charging port board.
完成的
添加一条评论
添加你的答案
Tinkerer05 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 179
