跳转到主内容
修复你的物品
维修的权力
商店
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB DDR5 Video RAM
571 个问题 查看全部
Swap display between 2011 & 2012 MacBook Pro?
Hi there!
Basically what I want to do is to take a high-res glossy(!) display from a primo 2011 Macbook Pro and use it as a replacement for the standard res screen on a mid 2012 Macbook Pro. Is this possible?
From what i've read its seems possible I'm not sure if the connectors will match.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
最有帮助的答案
100% works, "but". Typing this on a 2012 MacBook Pro unibody 15 with a 2011 Unibody 15" high res matt display and top case.
The keyboard failed on mine, so I swapped the display and top case (and went for the upgrade along the way as a toasted 2011 model wasn't much more than a top case).
The "but" is that the connector is slightly different. The wiring is identical, but you have to bend (not break!) the tabs at either side of the connector on the logic board, which is a delicate job. The connector then slots in and locks into place as expected.
这个答案有帮助吗?
得分 2
添加一条评论
Parts catalog says won't work.
11's fit only '11s - 12's fit only 12's.
If this answer is acceptable please remember to return and mark it.
MacBook Pro 15" Unibody (Early 2011-Late 2011) Display Assembly图片
产品
$149.99
这个答案有帮助吗?
得分 1
评论:
I know it says that in part-list in here but I have read about others who've done this successfully.
完成的
I'm confused. You already knew the answer but asked a question about it anyway? Then you should ollow the direction of the others.
完成的
添加一条评论
添加你的答案
Thomasgd 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 5
总计 758
