跳转到主内容
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318 个问题 查看全部
Dryer won't start Error Code F70
Just had a Thunderstorm and lightning hit very close to our house blew 2 circuit breakers. I reset them and everything came on in the affected rooms. When my wife tried to start the dryer it wouldn't start and has an error code of F70 flashing. What does this mean and wan I fix it or do I need a technician?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
1个答案
已选择的解决方案
Doug, F70 means check harness connections at the machine control and at the console electronics. If your connections are fine to the machine control board and the console electronics, then you may need to change the machine control board. Unplug your dryer first and leave it unplugged for a while to see if it resets It is below the top panel on the left hand side of the dryer panel. I attached the tech sheet for the dryer to the bottom of this page. Hope this helps, good luck.
这个答案有帮助吗?
得分 6
3条评论:
I replaced a circuit board run as described "https://www.youtube.com/watch?v=eWqrn5kl...: However, I did not properly seat one of the plugs. I reopened dryerthe board and checked the plugs. Once I found the loose plug, I re-seated it properly and the dryer came up perfectly.
Thank you so much for this excellent video.
完成的
Thanks to this information above I was able to get mine going too!!!! (Thank you)
完成的
coding F01 is iqual a F70?
完成的
添加一条评论
添加你的答案
Doug 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 65
总计 34,762
