跳转到主内容
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 个问题 查看全部
How can I make the home button work?
I am fixing an iPad screen and I accidentally pulled up the logic board connector for the home button.
This is the only way the home button will function, does anyone know how to reattach this connector? The old one also seems to be broken. Any thoughts are appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
it can be replaced---but sometimes it can hard to find that part. If yours is broken, then you'll need to replace it with one that is intact. Don't try superglue or conductive pen or any of that nonsense. If you have trouble sourcing the part or need to send out for a microsolder job feel free to click my name to find your way to my shop. I know I have a donor iPad 4 board that still has the home connector on it.
jessa
这个答案有帮助吗?
得分 0
1条评论:
Is that the only option? I want to be able to do this myself if possible.
完成的
添加一条评论
If you've pulled the connector off you're not going to be able to do it yourself unless you can solder (don't quote me on this) I don't fix iPads but when when I've dacidentally pulled off weak connectors I can always resolder them. i.e. iPhone 4/4s battery connector is held on by 4 very weak solder points.
这个答案有帮助吗?
得分 0
2条评论:
i can solder, but I've never done anything that small before.
完成的
that's what I mean, the points are so small it's very hard to do. I got a load of old RROD xboxes and used to use them for practice
完成的
添加一条评论
添加你的答案
Joey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 66
