跳转到主内容
Troubleshooting information and disassembly guides for garbage disposals.
5 个问题 查看全部
Kenmore garbage disposal - No sound, just won't turn on
What if you turn on the disposal & there is no sound, no hum? It didn't break down while in use, & I have tried to fix it--pushed button on bottom, checked for blockages, flipped breaker--to no avail. I don't have the right sized allen wrench for the hole in the bottom, but seemed to move around a bit & sound like it's got water in it when I tried another tool in said hole. I want to fix it myself before calling the landlord. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I finally have the answer, it was a loose wire in the toggle switch housing. No idea why it came loose, vibration must have done it with use. Thank you for your suggestions.
这个答案有帮助吗?
得分 2
1条评论:
My Kenmore disposer works (the motor works) but it stopped spinning
完成的
添加一条评论
Start Switch
On some models the stopper activates the start switch which is mounted into the upper housing of the garbage disposer. If the disposer won't turn or run at all the switch might be defective. The start switch can be checked for continuity and replaced if necessary.
Other Causes and Conditions
Wall Switch
If the garbage disposer won't turn or run at all the wall switch might be defective.
Non Serviceable Motor
If the garbage disposer won't turn or run at all the motor might be defective. The motor is not replaceable. If the motor is dead the disposer will have to be replaced.
这个答案有帮助吗?
得分 1
1条评论:
Please tell us what worked.
完成的
添加一条评论
添加你的答案
Trace 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 36
总计 18,636
