跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
591 个问题 查看全部
Disassembling the Anti-Glare Screen
If anyone is familiar with iColours, they sell colored inserts that go behind the apple logo on the lid. In order to install these, it is necessary to take apart the entire display housing. With the glossy model, the instructions are to use a suction cup/heat gun/credit card and take off the glass, after which it is very straightforward. However, the anti-glare model obviously is a little different. The only thing covering the LCD itself is the bezel/black trim. Does anyone know how to disassemble the AG model display?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Guide Published!
I finally published a guide on replacing the Matte finish LCD. You can find it here: MacBook Pro 15" Unibody Mid 2010 Matte Finish LCD Replacement
Update
I just went ahead and tried to remove the Matte LCD screen and was successful.
The key is to remove the bezel, which is attached to the assembly using doublesided tape, similar but not exactly as with the glossy screen. Underneath the bezel, the screen is screwed in just like the glossy LCD assemble. As with the glossy, a heatgun works for this purpose. One big difference from the glossy (aside from the bezel) is that there is NO coverglass. The matte glass you see is optically bonded to the display, which is screwed in underneath the bezel, and so using suction cups will not work.
It helped me tremendously by removing the rubber seal around the bezel first. Steps were:
1. Remove the display assembly as described in steps 1-20 of the glossy tutorial MacBook Pro 15" Unibody Mid 2010 LCD Replacement .
2. Applied heat around the edge to losen the tape.
3. Remove rubber seal on lower corner. Using the sharp end of the spudger helps.
4. Apply more heat
5. Wedge flat end of spudger between bezel and screen to remove, while applying heat gun.
6. Remove the LCD as in steps 31-36 of the glossy tutorial MacBook Pro 15" Unibody Mid 2010 LCD Replacement .
I still haven't put this back together, but it all came apart rather cleanly. I'll post how this goes back together once I get the replacement LCD.
Murdercity - Were you able to remove the bezel?
MacBook Pro 15" Unibody Mid 2010 LCD图片
指南
难度:
非常困难
3 hours
MacBook Pro 15" Unibody Mid 2010 Matte Finish LCD图片
指南
难度:
困难
3 hours
这个答案有帮助吗?
得分 3
2条评论:
+ Thank you for bring this back here. This does clear up the differences between the 2. Keep your double sided tape well protected. You will be using it again when the new lcd arrives.
完成的
Actually, the double sided tape was gone, but ordering more is easy. I don't think I'd want to have saved the old stuff anyway, as the bezel gets slightly bowed and so adhesiveness becomes a major factor. Better to get new tape.
The bezel went on cleanly, the project was a success. I took pictures throughout the process and will post a guide.
完成的
添加一条评论
This guide should help you: MacBook Pro 13" Unibody Mid 2009 Front Display Glass Replacement
这个答案有帮助吗?
得分 2
1条评论:
I assume you're implying that the procedure for removing the AG bezel is the same as removing the glass?
完成的
添加一条评论
添加你的答案
murdercitydevil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 7,768
