跳转到主内容
A 14 Mega-Pixel camera released in October 2010 identified by the model number C195.
14 个问题 查看全部
My camera says lens obstructed
my camera says "lens obstructed", does this mean I need a new lens, or can you give any other suggestions
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
2条评论
how can i fix the lens obstruction
完成的
deanranderson6 just like it is described in the original answer.....
完成的
添加一条评论
1个答案
已选择的解决方案
lisa rinehart, possibly but try the tricks from here first. I used a vacuum cleaner before and had the suction assist to free the lens. Should none of this work, you may have to replace the lens. Here is the guide for that. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
lisa rinehart 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 45
总计 6,717
