跳转到主内容
A Windows phone known for its camera capabilities. Also known as Nokia EOS, Nokia 909, Nokia RM-875, Nokia RM-877, Nokia RM-876.
42 个问题 查看全部
Memory Upgrade from 32GB to 64GB
I have a Nokia Lumia 1020 GB 32GB which is the usual standard in many countries except that
64GB is sold in certain EU countries. Is there a way if I can upgrade the memory
from 32GB to 64GB rather than buying a new phone. Any input would be
appreciated. thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
anjinsan, not unless you can a. get your hands on the memory IC's and b. have a reball station as well as the proper stencils and solder balls. The memory IC's are a BGA and can not be changed easily. So for the normal DIY'er the answer will be "no". Hope this helps, good luck.
这个答案有帮助吗?
得分 2
1条评论:
That's what I thought but wanted to see if there was another option.
thanks for confirming.
完成的
添加一条评论
Hi how can I find out what memory is my phone Nokia Lumia 1020 thanks
这个答案有帮助吗?
得分 0
1条评论:
Instructions on how to find them are here: http://www.windowsphone.com/en-au/how-to...
完成的
添加一条评论
添加你的答案
anjinsan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 5,369
