跳转到主内容
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 个问题 查看全部
iPad 2 touch screen not working after digitizer replacement
Hi, I have an iPad 2 which had a cracked screen, so I went online and bought a replacement immediately.
After the tear-down and replacement of the parts, I placed the screen on the device (without the adhesive) to test it before sticking it down. However the touch screen is completely unresponsive but all physical buttons work fine (home button, power, etc), So I wonder whether it's a faulty digitizer?
This problem is very frustrating as the iPad clearly works because the LCD is on, it syncs with iTunes etc. but without the touch screen, which without it makes it useless!
So I'm wondering what i could do next? Should I contact the company who supplied the new screen and request a replacement as I assume it's faulty OR should I assume that there is something else wrong on the iPad (ie logic board, faulty connector, etc!)
Thanks for reading and hopefully someone has some advice or even a solution to my frustrating problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
3条评论
i think that ,you have to make software after that you replaced the touchscreen.may be it will work fine.
完成的
Mine is somewhat similar I replaced the touchscreen desensitizer but it didn’t swipe properly. I have two gold pans at the bottom of my iPad too and don’t know what to do with them any suggestions of what I might have done wrong?
完成的
I had the exact same problem after replacing the glass on an iPad 4. The touch screen was totally non-responsive. I reseated the flex cable all the way in to where I could not see the white indicator stripe and the cable would not go in any further, then I locked the zif connector and it worked flawlessly.
Thank you for taking the time to post your solution.
完成的
添加一条评论
9个答案
已选择的解决方案
Hi, should have commented back before now but anyways, my iPads touch is now working great! Turns out the connectors weren't pushed all the way in! Silly me! The white lines need to be flush against the connector and requires some force with a tool to get it in properly!
这个答案有帮助吗?
得分 19
14条评论:
Thank you for having commented back on "The white lines need to be flush against the connector"! I had wondered why the touch screen replacement installed did not response. It works now. Thanks again!
完成的
You shouldn't be picking your own answer as the solution when it's obvious you didn't actually read what "con" wrote 5 weeks earlier.
完成的
Hi all,
I just did my first broken screen fix on the ipad2. omg crazy. I got it all back together and the slide feature didn't work. I came here and read your posts, opened it back up and my white lines weren't lined up. thank you thank you thank you! I thought I'd killed it! works great now, and its black! no more white ( I had wanted black to begin with!). Thanks again!
完成的
Thank you. Pushed the connecter in a bit more and bingo! works fine now.
完成的
Could you send the picture of what should be pushed in?, I cannot figure out what is the white line?
完成的
显示更多的9条评论
添加一条评论
Before you start blaming the motherboard make sure the connections are pushed all the way into the connectors and retaining clips pushed down if it is then most likely a faulty screen
这个答案有帮助吗?
得分 15
6条评论:
Thanks for the reply, all the connectors are fully plugged in. Display is working with the LCD, but still no touch. I'll get in contact with the screen supplier to arrange for a new one to be sent!
Thanks
完成的
Since this is actually the proper solution you should give "con" the credit.
完成的
Hi Con,
I have similar problem, however in my case only the lower part of the screen is not working.
Any solution you can suggest
完成的
Ryancoleman has issues that should not be allowed to be expressed in a fixit forum; find a therapist to resolve your passive aggressive issues. Haters waste time not people that only failed to see a past post.
完成的
YES~ This worked for me. The white tabs show up on the connection from the digitizer cable to the port where you plug the digitizer in. I used a black stick to nudge the connector in while holding the ipad down firmly. Now it works woohooo
完成的
显示更多的1条评论
添加一条评论
Hi
I tried replacing digitizer on the iPad 2. After restarting the lower part of the screen seems to be irresponsive, while rest of the screen is working. Hence the problem is getting the onboard key pad to work. Please let me know what i could be doing wrong while replacing digitizer screen
这个答案有帮助吗?
得分 0
添加一条评论
I’ve attached a photo of the white lines that need to be pushed in right up to the host connector.
这个答案有帮助吗?
得分 0
1条评论:
Thanks. This helped my save a 2011 IPAD. Lots of memorable pics and videos.
完成的
添加一条评论
请参阅图像内容:
这个答案有帮助吗?
得分 0
添加一条评论
Same problem...wish I read this blog sooner about having the digitizer's connection 'flush' when installing... I just replaced six digitizers to six Ipad 2s and the touch screen sensitivity is not there on each of them...the home button works though, which really makes me wonder. I'm hopeful that fully charging them will fix the problem, they've been out of commission for quite awhile
这个答案有帮助吗?
得分 0
添加一条评论
There is a ic chip for the touch mechanism that
needs to be replaced it's Micro soldering
and a professional needs to do that
这个答案有帮助吗?
得分 -2
5条评论:
say what? no touch in iPad 2 will be screen flex or connectors. I've repaired hundreds and never seen a no touch iPad 2 that was ic related
完成的
Yes there is a ic to everything like back light and everything else
完成的
No man, not in the iPad 2. There is no backlight LED driver chip in the line between the main power ic, and the coil/diode/filter and then the LCD connector itself.
But the is a TON of misinformation out there.
This might help to clear it up: http://mendonipadrehab.com/entries/gener...
完成的
tiken, would you please give a link to this nebulous ic and note its exact location.
完成的
What can I do I replace my Ipad2 touch but not working solution
完成的
添加一条评论
just give up and buy a new one
这个答案有帮助吗?
得分 -2
1条评论:
such good , must buy
完成的
添加一条评论
touc scrin not w
ouk
这个答案有帮助吗?
得分 -2
添加一条评论
添加你的答案
Ieuan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 27
总计 86,717
