跳转到主内容
The dual SIM version of Nokia's C2 series, released in 2011.
9 个问题 查看全部
How do I re install software on my dead Nokia C2-00
I came across this software update notification on my C2 after which i choose download and install. All went fine until the end when it finally restarted and gave a message" contact Service in white and the screen was a ll black. I tried to switch off but it was all non responsive. Now nothing comes on so am here to know if this is salvageable or I just forget it.
Regards
Zed
回答此问题 我也有这个问题
这是一个好问题吗?
得分 20
添加一条评论
6个答案
最有帮助的答案
have you tried to take battery out, and re-insert into phone. What happens if you do that?
这个答案有帮助吗?
得分 4
3条评论:
..Apparently yes, I recharged the phone just to be sure but even then, nothing came on the screen to show charging was in progress so after that I have removed & reloaded the battery, tried to power it but nothing comes on...
完成的
Then i would contact warrenty, because if the issue is data corruption or damaged certificate - it can only be fixed in a service center using a flash jig.
完成的
Ganon pare pag ginwa mo tan
完成的
添加一条评论
Hello, I am also facing the Same Issue :( is There any Solution please?
这个答案有帮助吗?
得分 1
添加一条评论
I am also facing this problem in my Nokia C2-00, I removed the battery and again inserted in the phone but it is not working, my phone is just showing white screen.
这个答案有帮助吗?
得分 1
添加一条评论
Same Issue i want nokia c200 os software
这个答案有帮助吗?
得分 1
添加一条评论
hardware id pass word forgoten .kinly send me nokia C2.00 soft ware id pass word
这个答案有帮助吗?
得分 1
添加一条评论
muje mobail pdet karna he
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
zbundi 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 7
总计 20,075
