跳转到主内容
Furby was a popular electronic robotic toy resembling a hamster/owl-like creature which went through a period of being a "must-have" toy following its launch in the holiday season of 1998, with continual sales until 2000. Furbies sold 1.8 million units in 1998, 14 million units in 1999, and altogether in its three years of original production, Furbies sold over 40 million units.
80 个问题 查看全部
Why isn't my Furby Boom speaking?
Furby Boom isn't speaking I've tried putting in new batteries, refreshing Furby Boom and tons of other stuff.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
... does it look like its trying to speak but no noise is comes out of the speaker when it does? Ive got a boom that also seems to be having speaker problems.too.....(its words sound broken,like the wiring is bad or something. I'm thinking speaker needs fixing/replacing....seems like many of those boom need either speaker or motor fixes)
完成的
添加一条评论
3个答案
已选择的解决方案
Cathal McHale, here is my answer to a very similar question "I would get to the "tummy switch" and check the circuit from there. You do have a couple of choices here. Check the switch, then the speaker. Check the connector for both. You will need a multimeter to check those. Follow the schematic to work on your Furby's voice, and check on here for directions on how to skin the Furby. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
1条评论:
I wouldn't know where the schematic ?
完成的
添加一条评论
Have you tried what a bunch of others with mute booms have trie....if the fault is in the speaker itself many have had sucess with poking the speaker membrane actually through the fur & plastic cover.....i have done something kinda similar and i took out the bad speaker and plugged in a better one.....ive found that if none of that works, it may require more surgery to fix/replace a faulty motor....diagnosing what didnt help is oddly enough can be great,MN frustrating but eventually great. Let me know if anything helps
这个答案有帮助吗?
得分 1
添加一条评论
my furby boom cant work either
这个答案有帮助吗?
得分 -1
1条评论:
What's wrong with it? The speaker as well, or?
完成的
添加一条评论
添加你的答案
Cathal McHale 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 3,673
