A series of 15" media laptops manufactured by Dell.
23 个问题 查看全部
Fix Corrupted Set Of Files In Hard Drive
This is with the Studio 1535(I'm not sure if this problem is the same to fix as it is with other studios?! Thought it was worth asking. Just recently hard drive diagnostic tested it, after not being able to by pass the "Loading Windows" screen and the test told me that I had about 10 files that were corrupted. Anywhere to even start with this? Thank You Very Much.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
4个回答
已选择的解决方案
Boot into your system disk and select repair drive. If that fails I think you will have to reload your operating system. Ralph
这个答案有帮助吗?
按维修分数 1
添加一条评论
最有帮助的答案
If you have important data you need to recover, I would suggest you get an ubuntu live cd, the live cd loads up using your ram, so you wouldn't use your hard disk, only when you're accessing the files using this live cd. After it's loaded, all you need to do is save your files into a flash drive. very simple. You can get ubuntu here http://www.ubuntu.com/desktop/get-ubuntu...
good luck.
这个答案有帮助吗?
按维修分数 2
评论:
Ubuntu or other distro, personally I would remove that walled os and go the whole way and install ubuntu. It's the future. Good answer +
添加一条评论
If recovering your laptop is a priority, you will need to remove the Hard Drive, and get a SATA to USB adapter, and if you can, pull all the data off. If this does not work, then you will need to send it in to a data recovery center where you will spend loads if you really need to (7k-ish).
What OS do you have? Assuming you have Windows 7, follow these instructions. However, I would recommend using the command : "chkdsk C: /r /f" without quotation marks, instead of chkdsk C: /r. It does a more thorough check.
In the end, if the cause of these corrupted files is because of a drop, you may need to replace the HDD
If this doesn't work, try using the startup repair selection, which I think ralph was referring to.
这个答案有帮助吗?
按维修分数 0
添加一条评论
If you have lost your important data from the hard disk, Use Kernel for windows data recovery software to fix error and recover all important data from your hard disk. Some time ago i was going through this problem and try this tool to solved all hard drive problems.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Tracy 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 5
总计 2,888
