跳转到主内容
Fourth generation of the Toyota Pickup.
49 个问题 查看全部
Truck shutting down while moving
symptoms started with all lights (cab, dash, headlights, tail) getting extremely dim, followed by several jerks from either the engine or the transmission, then when shifted into neutral the engine shut off entirely, when put back into any gear releasing the clutch would roll start the engine, but there was no response from the gas what so ever, engine oil is good, coolant and radiator are good, battery is brand new, fuses are good, lines and wires are good, air and oil filters are new, class 1 leak on the underbelly of the truck where the transmission is, engine will not turn over, upon attempting to start vehicle all lights that remain on dim.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Hey Sam
I am not a mechanic and my knowledges on vehicles are limited, but could it be that the alternator is faulty and your batteries are just dying because they are just not charged.
I found this interesting guide here: http://www.allpar.com/fix/nostart.html
That probably contains your answer
Good luck schusy
这个答案有帮助吗?
得分 0
添加一条评论
Hi Sam
After trickle-charging my 1984 Toyota's battery to full, my truck would eventually putter out in a similar fashion.
I could eek out a few more miles if I kept the headlights, radio, and brake-lights to a minimum (leading to some questionable driving habits for a week or so).
How's your idle? What I thought was an unrelated occurrence – a slightly high idle and reduced gas mileage – was actually the culprit.
The negative battery ground on a 1984 Toyota pickup runs to the choke. A bad choke will cause a "choke always on" symptom, and a bad ground will keep the battery from charging (even with good fuses, a working alternator, and solid wiring).
Keep on chasing the ghost Sam!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 365
