跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Spilled paint in earpiece microphone, now can't hear
I spilled paint on my phone and it got into the earpiece microphone (where you put your ear when you're on the phone). Now I can barely, barely hear the other person when I'm on the phone.
Should i replace the earpiece microphone?
I don't think that will do much. I opened my phone and there's nothing noticeably wrong with it. I think there is just dried paint in the speaker area, which I can't reach by taking the phone apart.
Thoughts? Please help! Thanks!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Hi
It just sounds like there's leftover paint in the wire mesh for the earpiece microphone. All you have to do is take off the screen, remove the earpiece assembly, peel off the rubber gasket for the earpiece microphone carefully, clean it, and then peel off the wire mesh and clean it out. Then just super glue the wire mesh and gasket back on. I've done it before so it is definitely possible.
Best of luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bhkonig 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,247
